Ravi Dhorajiya Posted March 10 Share Posted March 10 (edited) Hello everyone, I am trying to find a way to control a decimal precision on custom property manager on evaluated value on Solidwork 2017. https://drive.google.com/file/d/1WLBRjqbFt1YMhQ4drADQJMsGYMTkzy8m/view?usp=sharing Default setting is set to 2 decimal precision. Highlighted value coming from following sequence: 1) Reference sketch on top of the Sheet metal flat pattern and dimension given to this sketch are driven. 2) Use this driven dimension on equation feature to automatically get a flat size of parts 3) Finally use this equation value on custom property manager. Up to the 2nd step decimal point precision showing 2 decimal only, on 3rd step it will come 4 or 5 decimal . I really appreciate the help on this as I have spend unlimited hours to find a solution on this issues. Thank you Edited March 10 by Ravi Dhorajiya Quote Link to comment Share on other sites More sharing options...
Recommended Posts
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
