Jimmy Pho Posted April 18 Share Posted April 18 Hello, Where do I go in SolidWorks to change the line thickness for a PDF drawing output? The PDF line is thick when I zoom into the actual drawing. Quote Link to comment Share on other sites More sharing options...
Glenn Schroeder Posted April 19 Share Posted April 19 There are two things that may help. First, when you save as PDF, click on the Options button and check your settings. You may need to select a higher DPI value, but if that doesn't fix it take a look at some of the other settings. If that still doesn't fix it, try printing to PDF instead of saving as PDF. That often fixes issues, though it doesn't seem to be as big a problem as it was 10-12 years ago. Quote Link to comment Share on other sites More sharing options...
Recommended Posts
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
